treenester
- Jun 6, 2004
- 8
I have a 1974 MERC 500 that I just got. Was fishing a few miles upriver the other night. The motor ran fine. Started back to the landing & after about 1 mile, it just quit. I cranked it back up and it quit again. Kept trying & it finally cranked, but looked behind & it's smoking pretty bad (like a rich oil mix). I take off again & it doesn't go far till it quits again. I think it's out of gas, so I transfer some over from another tank. This takes a while so I crank it back up take off and it runs fine for about another 3/4 mile and then quits again. I try to crank now & it's tight (dragging). Oh no! It cranks & first thing I do is check the water discharge. It's hot, but not too hot to hold my hand under. Top of the motor is warm, and the back is warm through the cover (did not take the cover off). Starts idling rough, so I kill it. My fishing buddy pulls back around in his boat and I start it a few times just to show him what it's doing. We tow it in and I've not done anything to it. Was thinking about replacing the water pump impeller. When I first put the motor on the boat, I hooked the water hose to it & cranked it a few times to check the water pump & no water came out the discharge. I put it in the water & after about maybe 8 - 10 sconds water started discharging. My thought is that the water pump, though discharging a stream of water, was not pumping sufficient to keep the motor cool. What are some other things I could check? Anybody know what the compression should be on this model (ser#: 3817083)? I hope it isn't too late. Thanks.
