Diesel Bleedback - HELP
speedbumpf
1985 Chrysler/Mitsubishi 6ds7 engine with Nippondenso fuel injector pump.<br /><br />Problem: Bleed fuel system, engine starts and runs great despite fuel/air come out of one or two fuel connections at injectors when fitting loosend. Leave it overnight, try to start and will not without re-bleeding fuel system.<br /><br />Action to date: Replaced fuel hoses, filters and seals, priming pump. Ran hose from 5 gal drum direct into fuel pump. Still same problem.<br /><br />The big question: What can be wrong? Any help, suggestions or answers will be greatly appreciated as many mechanics are stumped.<br />Thanks
ron7000
Banned
Re: Diesel Bleedback - HELP
I had a '89 F250 truck with a 7.3L IH diesel so from that experience all I can suggest is that you still have air entering the fuel system somewhere. That's if the IP isn't on it's way out. By bleeding the system do you mean before the injector pump? if so, and that consistently cures the problem then that seems to suggest air is getting into the lines before the IP. If it's a mechanical fuel pump, try putting a gauge on the output side and monitoring how well it holds pressure. If it doesn't that consider that a source of the problem.<br /><br />Of that era, most injector pumps want positive pressure fuel supplied to them, around 6 psi. They will, or at least mine did, would pull fuel if you didn't supply it with fuel but it is not good for the pump and can lead to failure. Unless I misunderstand you, supplying fuel via a 5-gal drum to the IP isn't a good idea and also doesn't tell you much. Another common source of air entering the fuel system is at the injector caps. A solution to this, more of a work around actually, is replacing the mechanical fuel pump with an electric one. That will force air out of the lines quicker than a mechanical pump if the air leak is small. hope that helps some, if all else fails fork up the cash for a new IP, if the boat has a decent amount of hours on it (it's 20 years old) then your probably due for an IP anyway.
lilmandavis
governer seals or corroded line barbs. the bad thing is that when the ip's go bad, sometimes they rev out uncontrollably. sometimes without fuel pressure, the pump will suck in a seal as well
