Dieseling on shut down
Beefer
My brain seems to have abandoned me.
Motor starts and runs great, but Diesels when I shut her down. I know this is something (relatively) simple. Where do I start?
488R / Alpha I / Rochester Quad
Silvertip
Re: Backfiring on shut down
Are you confusing back firing with dieseling perhaps. A backfire is loud report whereas dieseling sounds like a rough running engine and may quit with sort of a muffled "puff". Dieseling is generally due to idle speed set too high or not being allowed to idle for awhile after a long high speed run before being shut down.
Beefer
Like I said... my brain has abandoned me...
Yes, it's dieseling. :facepalm:
RogersJetboat454
-Idle speed too high.
-Wrong part number plugs causing a hot spot (acting like a glow plug).
-Carbon build up.
halfmoa
Ensign
-Carbon build up.
Agreed +
-Overheating from blocked coolant passage
-Overheating from carb set too lean
-Incorrect octane i.e. 87 octane fuel in a high compression engine
Beefer
Thanks! Gave me some things to look at tonight. I run 87 octane mostly, and it only needs 87 per manual. Occasionally I run 89.
I'm starting with the carb adjustments.
