dieseling
Re: dieseling
How do you know if the engine is dieseling?, mine is a 4.3l 1991
Ayuh,.... Welcome Aboard,....
Dieselin' is when the key is turned Off, 'n the motor don't Stop....
is that what yer's is doin',..??
Silvertip
Re: dieseling
Ever see the movie Summer Vacation with Chevy Chase in which he comes home with a new Ford Station wagon that has a really bad make-over? When he shuts the car off it remains running but with a very ugly and rough coughing. That sir -- is dieseling. It can be cause by idle RPM set too high, fuel with an octane rating too low for the engine, engine overheated, timing too far advanced, to name just a few.
gabe4560
Re: dieseling
thanks for the responses, do that cause hydrolocking or is something different?
Re: dieseling
Ayuh,.... It sure Does,.....
The last sputter of the motor, is usually as it spins Backwards, suckin' in water from the exhaust....
nigels
Re: dieseling
Useful reading:
TO: SERVICE MANAGER TECHNICIANS No. 97-17
PARTS MANAGER; Revised July 1999;Engine ‘Dieseling’ or ‘Running-On’; Models MCM 4 Cylinder, V6 and V8 with Carburetors.
Situation
Under certain conditions, carbureted engines may ‘run-on’ when the ignition key is turned off. Normally, it will take a combination of several of the following conditions to make the engine ‘run on’. These conditions include but are not limited to:
1. Type and formulation of gasoline available in the area.
2. Type of boat and its engine compartment ventilation system.
3. Outside air, inside engine compartment air and engine coolant temperatures.
4. How quickly the engine is shut off after running at cruising or higher RPMs.
5. How the boat and engine are operated.
6. Engine idle rpm set too high.
7. Wrong heat range spark plugs or spark plugs with deposits on them.
8. Deposits in combustion chamber. Carbureted engines, unlike EFI, do not shut off the fuel supply to the engine when the ignition key is turned off. As the engine is coasting to a stop, air is still flowing through the carburetor into the manifold. This air flow can still draw fuel from the carburetor, through the intake manifold and into the combustion chamber. A hot spot in the combustion chamber will cause this fuel/air mixture to burn. The engine now ‘diesels’ or ‘runs on’ although the ignition system is not firing. EFI engines do not have this problem because the injectors do not inject fuel once the ignition key is turned off.
Suggestion to Minimize ‘Run On’
Items number 1 ,2 and 3 can correct or reduce most of these ‘run on’ problems. Letting any engine idle a minute or two before shutting it off is desirable. This helps the engine to normalize at idle rpm before being shut down.
1. Be sure engine idle mixture, idle rpm and ignition timing are correct. On 4 cylinder and V6 or V8 engines
with Thunderbolt IV ignition, setting idle rpm as low as possible can help stop ‘run on’.
2. Adjust throttle cable barrel so that the carburetor’s throttle lever returns against the idle speed stop
screw every time the remote control throttle lever is returned to neutral, idle.
3. Idle engine 1 to 1-1/2 minutes before turning key off after running at cruise or higher engine rpm.
4. Try a different brand of regular fuel or try some premium fuel.
5. Increase idle mixture by 1/8 turn ‘richer’.
6. Go to next colder heat range spark plugs.
7. V6 and V8 only: Install a 140 ?F(60 ?C) thermostat.
Available Colder Spark Plugs
Original Spark Plugs in the Engine:
Short Reach Spark Plug Long Reach Spark Plug
AC-MR43T AC-MR43LTS
Replacement
AC-MR41T AC-None
NGK-None NGK-TR6
Champion-RV12YC Champion-RS9YC
OR Champion-RV91MC
NOTE: Quicksilver does not stock these colder spark plugs. They will have to be ordered from a spark plug distributor
