Re: Difference between epoxy or poly layup?
You can't use CSM with epoxy - the binders in it are only broken down by polyester resin.
Epoxy is good if you are going to use foam structurally - polyester has styrene in it which dissolves foam. Most people glass over plywood forms rather than foam forms/cores however.
Secondary bonds onto old polyester are better made with epoxy, although I've not heard of anyone having disbond issues with properly sanded "old" polyester.
Be aware that polyester finishing resin is "waxed", which means it contains a wax which floats to the top of the layup. You will need to properly surface prep if laying up on top of recently cured poly (i.e. sanding). With epoxy you can use peel ply, probably not compelling enough alone to justify the cost but something to be aware of if you have a ton of secondary bonds to perform.
