Re: difference between v4 Evinrudes.
Hard to tell exactly what comparison you are wanting to make. The 110 engine in 89 is a crossflow engine. An 89 140 is a big bore looper, completely different engine. If you are comparing your crossflow with the older 140 crossflows from the early 80's, keep in mind that a main difference is the hp rating systems which changed about the 86 timeframe. A pre 86 (or maybe 85) engine was crankshaft hp rated. The later engines are all propshaft rated. That's a 8-9% adjustment (downward )for the friction of the gearcase on the later year models. Your 89 110 is very similar to the 140 crossflows. Yours has the large carbs on it. The main difference from those early engines is that your engine has low compression bathtub heads and does not have the rubber intake filler blocks (322684), which are good for 3-5 hp. Your ignition power pack limits rpm's to 5800, while the older engines ran unlimited factory packs.
