differnce between boat and auto parts
ibuildcars4u
what is the difference between a boat carberator, and an automobile carb ? and a boat fuel pump and a automobile fuel pump?
Farpoint
Re: differnce between boat and auto parts
doubt any difference in either except marine gaskets for carb
jimmbo
All are designed to prevent fuel from being dumped into the bilge. Carbs must be designed so no fuel seeps out of the carb via the throttle shafts. Float bowl vents also have direct spillage away from the bilge Mechanical fuel pumps will catch any fuel that gets thru a leaky diaphram and send to the carb instead of letting it drip into the bilge. Same thing with starters, altnators, and distributors, all are designed to prevent any gas fumes from getting inside or sparks from getting inside. Using auto parts in a boat is unsafe and againt USCG rules, in other words Illegal.
Bski
I came across an interesting one the other day, the spark plugs have a M in front of the # which refers to marine. The only thing I could think of is that they put some kind of coating on the outside to prevent corrosion.<br /><br />Definitely a big hole in the water that you pour money into. <br /><br />My other favorite: The two happiest days of a boaters life, the day he buys it and the day he sells it.
