I hope someone can help me with this problem-<br /><br />I have a 1987 Bayliner Capri with an OMC 3.0 liter and cobra outdrive.<br /><br />When the motor is not running the throttle/gear selecter will move easily from reverse to neutral to forward. When the engine is running, however, it is very difficult to move the selecter from neutral to reverse or forward. I have to smack it to get it into gear. There is no noise or grinding/clunking, just a lot of effort.<br />I have removed the cables from the carb and outdrive at the engine and found them to move freely- so I don't suspect theat the cables are binding. <br />I'll also add that this boat and drive unit have very low hours (less then 100) and are in VERY good shape. The boat went unused for quite some time, but I used it all last year with no problems. The engine runs excellent.<br />Any ideas?
