Welcome aboard.
Did both gauges start dimming or both go out at the same time?
You say you have power, but how much power? Digital displays will dim if the voltage is low.
Measure the voltage to the gauges and it should be over 12 VDC. Also it would be worth while to clean both the voltage and ground sources to the gauges.
