JoLin, no worries, didn't hijack. The instrument gauges are fine, they use old school bulbs and are very very dim (which is a good thing). The main issue I am having problems with are the words and toggle switches. No lighted toggles, no lights behind the words above/below the toggle.. ie -- One toggle is an ON/OFF/ON (flip up is bilge pump, flip middle is off, flip down is blower fan). I'd hate for myself or something to turn on the bilge pump and leave it running and it burn up because they couldn't see which switch they flipped, and/or didn't know it was on. -- I always turn my blower on and let it run for a bit before starting the boat. Normally, I'm still in the water and ask someone to flip the blower on for me while I finish bringing in the anchor off the beach, cleaning up and pushing the boat away from shore. The marine/auto maplight would indeed work, I have also looked at license plate lamps. I think the thing holding me back from those two options is those are "add ons" and takes away from the original dash/instrument cluster. I've been shy about adding new holes, screws, etc into this project. The photo above is an older picture, the boat has been completely stripped and redone back to original form.
I may just pull the original dash panel, make a new one and add/remove what I want, so it works for me. Add the map light, remove speedo, etc. I'm odd like that, I want to keep the original, put it in a safe place lol --- does anyone else do stuff like that?
