Dimentions for motor stringers for Volvo Aq
robjen1019
I am looking for a diagram that has the dimensions for the stringers or supports for the Volvo aq 151 s4 and the aq 225 v8. Trying to put my 151 in a hole built for a aq 225.
Thanks
dubs283
Re: Dimentions for motor stringers for Volvo Aq
so this is a 4 cyl motor that you are putting in a boat that originally had a v-8?
robjen1019
Little trial and error and I figured out what the difference is between the stringers on a v8 and l4 aq volvo penta.
The Motor mounts are the same distance from the transom.
The mounts for the V8 are 2 inches higher than the l4
the mounts for the v8 are out 3 inches wider on each side for the v8.
Ended up being an easy fix the swap the motors.
captmello
I'm impressed, now you've got two boats to maintain.:eek::eek:
robjen1019
nope, giving one away to a friend. I just wanted the motor
