Dip stick oil leak
rebars1
I'm restoring a 1971 Trisonic, ford v8 188hp, R outdrive. I have a small oil leak from the dip stick holder at the oil pan. It looks like it is seeping from between the metal plate that is rivetted to the pan and the pan. Can this be sealed with something?
Bob_VT
Re: Dip stick oil leak
Get it real clean, dry and free of grease and oils... use JB Weld. That is not a spot subject to any pressure.<br /><br />Bob
rebars1
Thank you for the information. Should the paint be removed also?
Catchem
Rrebars1,if your able to take the pan off,clean it and use silver solder to fix it.Had the same problem on an old car of mine and the solder worked like a charm.Also nice to clean any sludge out in the pan too to keep clean oil clean.
rebars1
I can't take the pan off w/o pulling the engine. I applied the JB weld after sanding the area down to bare metal. I'll let you know how it works. When the time comes to pull the engine, I'll solder it. <br /><br />Thanks.
