Dipstick foreign object removal
MacShorty
1973 Mercruiser 255 been trying to remove broken dipstick from port engine for months. Finally got a good visual angle and light and realized the object stuck is a friggin t.v. Rabbit ear antenna! I have jerked and pulled in this thing with vise grips to no avail. Any suggestions? If I cant get it out in at least hoping I can still suck the oil out for an oil change.
Thanks for any suggestions.
flyman219
The antenna most likely has a "cap" at the end. I'd say you're going to need some patience trying to get it aligned with the end of the oil dipstick tube. You might try making a loop in the end of a piece of heavy piano wire to move the end of the antenna from side to side to hit the sweet spot.
Mike
pull drive, pull motor, pull pan, remove object, reinstall motor, realign, reinstall drive - 2-3 hours of work
how much time have you spent in the last month trying to do it the "easy" way?
MacShorty
I was wrong, it actually is the original dipstick in there. Not that that is any better. ;)
Guess this project can wait a while since I don't have the tools or resources to pull the engine by myself. Its a 43' houseboat so it won't be sitting in a driveway with a cherry picker. Gotta work up to bigger projects since I'm a boat newbie. :). Thanks for the education and ideas!
alldodge
Something doesn't add up, or I'm way off (which does happen). The 255 is a Ford 351 used as an inboard (house boat type)
The dip stick is installed using a compression type fitting which is screwed into the bottom side of the oil pan.
What am I missing?
if that is the case, drain the oil, unbolt the dipstick, remove object, reattach dipstick, add oil, drink a beer - 1 hour worth of work.
MRS
That is what I was thinking but I would have done two beers.:very_drunk:
