Direct replacement for OMC 5.7 Rochester quadrajet
ss9940_2
Hi there fellow iboaters!
Can any 1 suggest a direct replacement for a Rochester quadrajet? The engine is a 5.7 OMC, GM Engine. I would really need a "bolt in" carb, don't wanna modify anything.
Thanx in advance,
Alex
wire2
Re: Direct replacement for OMC 5.7 Rochester quadrajet
I believe both Holley and Edelbrock offer marine versions of popular model carbs, but they will probably not bolt on directly. The quadra-jet has 7/8" primaries, 2-1/4" secondaries that make it somewhat unique. You might have to replace your intake manifold also.
I'm curious why you want to lose the quadra-jet? Mine has run flawlessly for many years.
ss9940_2
Hey!
It's cause the old one is junk. Doesn't work right after 2 rebuilds. Plus, the fuel economy is supposed to be far better with an edelbrock or holley
KaGee
Hey!
Couldn't be the rebuilder, could it? :rolleyes:
Or another thought... maybe whatever problem you have is not the Carb? ;)
ron7000
Banned
Thanx in advance,
Alex
direct replacement from holley is a model 4175. It is a spread bore carb, opposed to the traditional holley square bore and will drop directly onto whatever you had the QJ sitting on. So you wouldn't have to change your intake manifold or use a manifold adapter/spacer. But it probably won't be a complete drop in, things like the fuel line fitting and throttle cable bracket may need replacing and the holley has electric choke so you'd need to wire it to the ignition, all of which is simple and holley is pretty good with parts like that.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY-0-80552&N=700+115&autoview=sku
Coors
What is the problem, exactly?
