whitesharkseeker
- Nov 8, 2010
- 95
Is this disc trailer brake shot? Seems very rusted but not sure when to replace them. They seem to work ok.
Thanks in advance, Eric 22' Davis
I swapped mine to Kodiaks, threw-away all that rusty crap.
Does the caliper still work?
We've had the viewing, when's the funeral?
A very easy method for determining if trailer brakes are activating...drive over a large sand or gravel area with your rig at a moderate (safe) speed and apply the brakes firmly...if the trailer brakes are working, they will most likely drag on the loose surface, leaving you telltale skidmarks.
