disconnecting idle stabilizer on mariner 200efi
20vector
hello i have a 98 mariner 200efi and want to disconnect the idle stabilizer on it.its runs fine at idle.can i just disconnect it and not retime it.i read stuff about disconnecting it and to check timming.but was wondering if its idling fine now that timming should be good.thought if its idling fine the idle stabilizer wasn't doing anything?please help i plan on disconnecting it and don't want to mess anything up. O and another thing if i disconnect the dentonation module do i have to do anything if i do? thanks in advance. ted
20vector
Re: disconnecting idle stabilizer on mariner 200efi
hello. got another question. was thinking about disconnecting the detonation sensor and module. was wanting to know what steps i have to do to elimate it. dont know if i should elimate all this but read on some forums that said to. was wanting to make sure this isnt what is makeing mine bogg down on take off sometimes.but dont want to mess it up more so if i shouldnt please let me know.thanks in advance ted
veritek_dragger
Hello vector I have the same bogging issue on my 96 200 efi.....did u ever disconnect these modules and if so what was the outcome? Let me know thanks so much
CharlieB
Resetting timing upon removing the idle stabilizer is more about WOT timing than idle smoothness. Idle speed is adjusted with idle timing. WOT timing is a combination of trigger position and Bias to the switchbox from the idle stabilizer, which is way you want to remove the stabilizer, when they go bad and advance timing too much at WOT the rods can come right out of the engine.
