Re: disconnecting oiler
Disconnect the wires coming from the oil tank and the VRO. Make sure to use 50/1 premix. May want to run it on 50/1 mix before disconnecting the oiling system. Also check out the hot horn to make sure it works. Do this by disconnecting the tan wire back on the mtr from the temp sender, turn your key on and ground out the wire. You should get a horn.
