Disconnecting the oil injection on Yam 30
Bwalker
Has anyone done this and what does it entail? I assume a plate is needed when the pump is removed. Does Yamaha sell one?
swist
Re: Disconnecting the oil injection on Yam 30
Why would you do this?
Bwalker
Because the 30 or so other motors we run are not injected and even with the oil pump maxed out it still doesnt use enough oil.
gov2mod
Why don't you leave it hooked up but go ahead and add a little more oil to the fuel tank to reach the desired amount.
Bwalker
Thats what i have been doing, but the problem is we have a 1000 gallon tank filled with 50:1 mix. The oiler put out about 109:1 according to my calculaitons. This might be a bit much as far as oil goes, so I would rather just disconect the works and run premix.
gov2mod
Ben, with that quanity of fuel I now see your problem. But, you've been of some help to me. I've got a 40hp Yamaha I'm getting ready to use. As with any older outboard I'm not running 100/1 as I don't think it's near enough. If the factory oiling system is running approximately 100/1 then If I mix my fuel 100/1 and leave the oiling system hooked up it should come out to about 50/1. Does that sound correct?
cpj
Ensign
I took the pump off my 115 yamaha.I removed the pump,took the drive shaft(for lack of better term)out,bolted the pump back on and away I went.Might not be the best way to do it,but... so far so good.
Ray Neudecker
There is a plate available for many of the Yamahas if you look up the consumer value model of the same HP. They came without oil injection. On the V-4 and V-6 models, a nickle epoxied in the hole will also work.
Bwalker
Dont happen to know the part number for the block off plate on a 03 60hp do you?
gov2mod
Ben Walker, what do you think about my previous question? If the oil injection on my 86 Yamaha 40hp is putting out 100/1 mixture and I premix my fuel at 100/1 will that give me my desired 50/1 ratio?
Bwalker
Yes, that would work, but I have a 1000 gallon tank of 50:1 mix. I dont want to have to haul seperate gas cans for one motor.
gov2mod
I understand your problem from your previous post. I've only got a couple of outboard to worry about. Until I read yours I wasn't aware of what mixture the oil injection was but I know that after losing a cylinder on my older 50hp Johnson due to the 100/1 mix I wasn't going to run that thin of a mixture again. I'd much rather have too much smoke than a fried engine. Thanks for the help.
