Disk Brake Installation.
edgutgesell
I currently have a tandom wheel trailer with drum brakes. I replaced the 4 brake assemblies three years ago and since my boat is used in salt water, the brake assemblies are really starting to corrode. I am going to replace the drum assemblies with disk brakes soon. I am planning to purchase Kodiak disk assemblies. My boat is a 4500 lb Wellcraft. My question is:
Is it an absolute requirment that I replace the 4 drum brake assemblies with 4 disk brake assemblies? Can I get away with having 2 heavy duty or larger disk brake assemblies on one axle? If so, which axle, front or rear? There is an equalizer between the front and rear springs.
I ran this boat and trailer without any brakes for about a month and my truck brakes were more than able to stop truck, boat, and trailer very quickly.
Geek
shepster
Re: Disk Brake Installation.
I just got rid of a Venture trailer that only had brakes on the front axle. I towed a 23' Maxum, 5000+lbs, and it did just fine for stopping. Always did inspections and flushed. If you opt for just one set they have to go on the front axle. Just like a car the fonts do 70% of the braking. You can always add the second axle later if money is an issue.
dingbat
My trailer is similar in weight to yours and I only have 1 set of Kodiaks on it. My tow vehicle has 4 wheel disks that provide pretty decent braking but certainly not enough for every day usage.
I had to lock them up last week and the axle with the brakes skidded so hard that the tires actually smoked. Not good for the tires and provided very little braking power to the situation. Most likely going to add a second set of brakes next Spring.
With a spring suspension system, the rotational torque applied to axles during braking shifts the equalizer and applies more weight to the rear axle.
Therefore when only one brake axle is being installed on a tandem axle trailer, it is advisable to have brakes on the rear axle for maximum system performance. If brakes are installed on the front axle, the wheels may skid during braking.
mikeneal
I have 4500# boat with tandem Kodiak disks. Trailer came with single set of brakes about a year added a second set. It is the law in FLA that all axles must have brakes if the trailer is over 3000#. I can tell you my opinion since I owned it both ways, under "normal" braking the single set stopped fine,but under hard braking the double set stops way better. My opinion is brakes are cheap and accidents are not so I always have lots of good brakes.
edgutgesell
Thanks for the replies. It looks like all 4 wheels for me!
Geek
reely hooked
Check your state laws. Some states, including Pennsylvania, require brakes on all wheels, not just the front ones.
bruceb58
5 1/2 year old thread brought back to life. Is this a record?
