Re: DISS Simular metals
To explain the passive and active business, you have to understand that stainless steel behaves somewhat like aluminium. There is a thin protective oxide layer that forms over freshly exposed stainless which is known as the passive layer, as opposed to the active material beneath it. For maximum corrosion resistance, freshly machined or forged stainless steel parts are often "passivated" which encourages a thick, more durable passive layer. Somewhat like anodizing aluminium.
In the case of a washer, likely some of the passive layer will get rubbed off the by the bolt head. So you can presume both active and passive stainless are in contact with your silicone bronze bolt.
Interestingly, it's the potential difference between the passive layer and the active material that premotes the formation of pits.
On a more practical note, since they're above the water line I doubt those fasteners will give you trouble in 40 years let alone 20. And if they do I'll bet the 5200 holds the halves together just fine anyway.
