- Mar 8, 2009
- 42,642
Had to replace the fuel tank on my dump truck and went to Aluminum instead of steel. Tank comes in and looks good, but has brass fittings in the top. Dissimilar metals tells me that brass and aluminum is not a great thing. Its not terriable but not real good. The brass fittings are for plugs and fittings for the fuel lines.
So do I use some kind of coating on the brass fittings or just change all the fittings to aluminum, galvanize or zinc?
The worst part of the issue is the manufacture of the tank did not know the answer. I was on hold for a while until they found someone who had a slight clue.
