speedyfreak24
- Jan 3, 2008
- 19
I am planning to convert my Thunderbolt IV ignition back to the factory setup with riser-mounted module, coil and distr. The previous owner installed and ran an auto HEI distributor with the coil set on top of the dist. cap. Not realizing, i ran the boat for 2 months last summer (454 BBC) and it idled steady, great acceleration, good starting, etc. I know about the marine spark protection.
Can someone explain how they would expect my boat to run with the auto distributor vs. marine, given the different timing curve demands that I have read about in car vs boat motor?
Beside the spark issue, is there any other detriment to the motor if I have to run the auto distributor for a couple months before I can afford the conversion?
Thanks in advance!
Thanks in advance!
