Distributor cap corrosion
DTM
Alpha 1 5.7L '86 Thunder bolt ignition - I replaced the ignition sensor in three months ago, cleaned cap and sprayed inside with WD40 and put a new gasket on the cap base. Yesterday took boat out to run in my new SE106 upper drive, have done 6 hrs over the last 2 weeks, so I have been using it. Motor ran good for 10 minutes then started to miss and run rough. Took cap off and found corrosion on terminals inside cap. Cleaned it and away she went, like a rocket.
My question is, why do they need a gasket when the distributor cap has a drain plug in the side that lets moisture in?
Previous to the ignition sensor fault, I had not had the cap off for 5 years, without any problems.
Just wondering why all of a sudden its corroding?
Grub54891
Re: Distributor cap corrosion
Its been corroding for 5 years,it finally got bad enought to cause issues,replace it!
DTM
Just to clarify, in January when I changed the sensor it wasn't corroded badly (this was after 5 yrs years without checking it). I cleaned and sprayed it ith WD40 and now after only 3 months it is badly corroded. I cleaned terminals inside with light sandpaper.
Grub54891
Ok,dont know why it corroded,wd have anything to do with it? My guess is yes,that should be dry under there. Anything in there bit air can make an electrical " channel" for wandering spark.
Grub
