Distributor Cap
1994almeida
On my Volvo Penta 5.0 GI PWTR from 1999, I would like to know your if the Distributor Cap is OK?.
I send 2 photos, before and after cleaning. There are too much burning, wear or corrosion?.
The Distributor Cap Shaft also has corrosion and I use WD 40 to remove the corrosion. It is sufficient or should I use some grease?
Before the cleaning, the engine starts well and runs properly.
Thanks, Almeida
1994almeida
Re: Distributor Cap
One more photo
1994almeida
Re: Distributor Cap
So, it is enough cleaning?
But according Seloc Manual Distributor Cap should clean with soapy water?
jeffnick
Re: Distributor Cap
I wouldn't hesitate to use it. Looks like it cleaned up pretty well to me.
Grub54891
Re: Distributor Cap
Seen worse also,run it,order a new set,keep it in a dry safe place and replace it next time ya do the maintiance/oil changes.
Grub
