Distributor Rotor
RSHOOTER
Mercruiser 3.0 ENGINE SERIAL NUMBER 1A014158
Is the Rotor cap sealed with Loctite? If yes what is the best way to remove it?
Thanks.
Don S
Re: Distributor Rotor
It shouldn't have loctite, let's put it that way. I have seen them froze on due to rust, and some just plain hard to get off.
TilliamWe
Banned
Thanks.
Pull up really hard! Or break it off !CAREFULLY! with a chisel or some other tool like that. It's just stuck due to rust.
When you get it off, clean up the shaft a little before you put the next one on.
fat fanny
When I bought my rig w/ 3.0LX the cap and rotor were both stuck, the cap was not seated in the grove around the electrical contacts correctly and the rotor suffered the fate of that missalignment due to condensation from winter this of course was a est ignition. Just pop it up possible slide hammer with 2 jaw puller just lightly! GOOD LUCK
zbnutcase
If possible, use of a heat gun can help. 'nutcase
Ayuh,... Channel-lock pliers,+ a slight Twist is about all it takes to shatter it....
