Re: distributor swap
Dgp<br />It is easy to wire and just depends on the unit you get if you use the same coil or not.<br /><br />Question I have is if it fails on the water can you fix it there and will you carry the parts needed??<br /><br />My 1980 model has had the points changed one time because I thought it was a good idea. The parts need to fix it will fit in a normal spark plug box an I can change in any weather in 10 minutes with just a screwdriver. In 23 years has never failed one time. To get it perfect need a feeler guage or dwell meter, with just the eye easy to set where it will run fine to get you in.
