Do boat alternators have to be specifically for marine purposes?
samocamo123
I believe the alternator is dead on my 1986 Ebbtide Montego 170 with a 1985 OMC sterndrive, model number 302sthrcom and I was wondering if I had a car alternator that fit in the boat, would it work, or would the marine conditions kill the alternator? Also is rebuilding a marine alternator the same as rebuilding a car alternator or is it impossible to rebuild it without destroying any waterproofing?
samocamo123
http://forums.iboats.com/forum/boat-...nterchangeable
Take a look around, lots of great info in here, no waiing for a reply.
If you dont like the forum search feature, use google and add
Iboats forum
To your search terms.....
I was also hoping to get a response about the rebuilding of marine alternators, and sorry if their is a post explaining the my rebuilding question, I didn't see one.
If its on a boat it needs to be SAE 1171 compliant. PERIOD. so yes, it has to be marine
GA_Boater
The only difference between marine and auto alternators is spark shielding in case openings of marine versions to reduce the chance of sparking a fire and to meet the SAE requirements. The guts are the same.
An auto shop should be able to rebuild a marine alternator.
That would be a good or quality shop will be able to rebuild it
samocamo123
Thanks, I noticed we both live in Canton, GA, its a small world.
GA_Boater
One of us lives on the right side of the tracks then. Or the wrong side! LOL
tpenfield
Actually an automotive alternator is more likely to do you bodily harm :eek:
Just to add to what the others have said . . . your boat is basically a bathtub that can hold gasoline vapors. All the electrical and ignition stuff that resides in the engine compartment should be SAE J1171 rated for spark suppression.
southkogs
I have an auto parts store here in Nashville that does a lot of rebuilding of electric motors. He understands marine application and has done several rebuilds for me - so, you can find a good shop that can do the work.
samocamo123
Does anyone know what alternator would be a good replacement for the alternator in my boat
GA_Boater
Take the alternator to AutoZone for a free test. I almost live at the one on Marietta Highway I spend so much money there.
HT32BSX115
Howdy,
Go to http://epc.brp.com/ to find your model number. You'll find that the OEM model number of your ALT assy is OMC 0983424
If you do a simple Google search of that model number you'll get every source of replacements. From $400+ Evinrude/Johnson to Sierra (sold right here on iBoats) to many other after market choices.
I would test that alternator first and probably then if defective, take it to any reputable auto electric shop for rebuild.
Regards,
Rick
