Do Cement Trucks have 2 motors?
eeboater
I was wondering that on the way to work this morning... They always have that big motor on the back turning the cement bin.. but is that motor also powering the axles?<br /><br />Anyone know?<br /><br />Sean
Nos4r2
Re: Do Cement Trucks have 2 motors?
Yes they have 2 motors- the trucks are the same as any other with that cab. The drum is an add-on by a specialist builder.
JRJ
Old mixer trucks had two motors. They now have one motor and a hydrolic pump to turn the drum. Now days, the hydrolic pumps are constant, powered by a shaft from the carrier motor.
clanton
The big motor on the back powers the truck, and a hyd pump to power a hyd motor, to turn the cement drum.
Nos4r2
Thats a new development I've not seen yet- usually when you hjave a hydraulic PTO engaged it's so hard to change gear while driving you have to turn it off-and they have a max rpm rating of about half what the main truck engines do.
Limited-Time
Generally the barrel is driven by a hydraulic motor that runs off a pump driven by the diesel engine that powers the drive line. Does that answer you question or just confuse ya......like it did me when I re-read it.
eeboater
LMAO Clear as Mud. Just kidding. I get it - thanks.
Limited-Time
Hay I have a question: do the cement truck barrels rotate the opposite direction in the southern hemisphere? Edited after posting: Apologies to ee did not mean to hijack your thd.
monoshock
I like the little Jeep signature, neat.
eeboater
LOL np LT...<br /><br />Thanks Mono!
NYMINUTE
Hey eeboater......I can get ya a deal on a cement truck. Only used to assist da boys in making shoes. I can have the boys pay you a visit?
QC
Just to be hyper correct . . . They are not Cement Trucks. They are Concrete Transit Mixers. Cement is the powder and is carried in a very different truck that is sometimes called a Cement Train or a Bulk Tanker. Concrete is the combo of the cement, aggregate (rock and sand) and water. Transit Mixers vary quite a bit from region to region. LT has the most common configuration down though. One engine and one motor. Motors are driven, engines drive . . .<br /><br />Transit Mixer<br /><br />
<br /><br />Bulk Tanker<br /><br />
monoshock
I tried to make the Jeep, couldn’t get the grill. <br />Sorry about getting off your subject.
eeboater
Originally posted by NYMINUTE:<br /> Hey eeboater......I can get ya a deal on a cement truck. Only used to assist da boys in making shoes. I can have the boys pay you a visit?
Fuhgetaboutit... Ma Cuzin Jimmy has a pair an hees sleeipin wit da fishes.<br /><br />Sean
NathanY
If you look at the picture of the mixer that Qc posted, behind the front bumper is a hydraulic pump. That pump is connected directly to the front of the engine at the crankshaft. That is what turns the mixer drum.
QC
Yup, most of them now are flywheel mounted and you can't see them, but in this case there is a reasonable view of the pump. You can even see the lines going under the truck and coming out into the hydraulic motor in front of the drum . . .
roscoe
Hey, there's a post from clanton. Cool.<br />Somehow its fitting that the subject would include hydrolics. :)
Kiwi Phil
Yep, mixer bowls turn the opposite way in the Southern Hemisphere to the Northern......<br /><br />What I am interested to know is: what does 1 cubic metre of concrete weigh?<br /><br />Cheers<br />Phillip
one more cast
What about the ones that look like they are going backwards? <br />
