Does this sound like i have a bent shaft.........First off, everone knows that there is a little gab inbetween the prop and the housing the prop is in. Mine is around a quater of an inch or less. The reasonn i am suspecting a bent something is because when i spin my prop at certian points the prop is a little higher agianst its housing than at other certian points (i guess that can be assumed as a wobble) it doesnt hit the housing it just doesnt spin EXACTLY the same in one fluid motion. However, i have taken the boat out probably 20 times and have had NO problems with it whatsoever!! I purchased the boat from another individual who must have hit something because i know i havent! the skeg under the prop is bent barely to the left when looking at it from behind. What damage could i cause by running my engine if indeed something is bent?? But like i said i havent had any problems with the engine running normally even at WOT! Help please!
Thanks.
Thanks.
