Do i have a blown head gasket?
cubajorge_2008
I have 2002 rinker 180 with a mercruiser 3.0. Engine hydrolock on me few days ago. I did a leak down test on the cylinders and while blowing air on number 4 i can hear air coming from carburetor opening. From cylinder 3 and 2 i can hear the air from the opening where you add the oil on engine. And from number 1 seems ok no air leak. Those this mean the gasket is blown or bigger issue?
could be bent valves and/or pushrods as well.
pull the head and look. you already know you need to go that far.
the cause of the hydro-lock needs to be investigated as well.
cubajorge_2008
The engine will turn when the spark plugs are removed but when i put them back nothing... will be pulling the head today and see how it looks
cubajorge_2008
This is how the head looked. I water pressure the manifold with water and air and is not leaking either. Im puzzle here. How you guys see the head and block?
the mating surfaces need to be cleaned up and checked with a precision ground flat-edge and feeler gauges
Bt Doctur
look like #1 has a puckered exaust valve, Nos 2and 3 have sticking/bent exaust valves
