Do I have tilt & trim????
jpendergrass
Was looking at this 76' Johnson 135 and I'm not sure it has trim. I only see 1 ram on each side of the motor, the calco pump assembly. I thought if the motor had trim there would be additional rams also. Am I mistaken??
mikesea
Re: Do I have tilt & trim????
its probably the older external type system,if you can enclose a pic.I can be ore accurate.But ,it probably is the ols system.The newer style have 3 rams ,enclosed inside the bracket assy.makes the engine more compact,it has a main tilt ram,and 2 trim rams for refinement of trimming out the boat.
