Do I have to remove the hing pins and gimble housing to replace my bellows?
Yes....
Why does he have to remove the gimbal housing just to change a bellows?
You guys must be reading something that I don't see, because you DO NOT have to remove the GIMBAL HOUSING just to change the bellows.
you guys must be reading something that i don't see, because you do not have to remove the gimbal housing just to change the bellows.
why are you shouting don? Don't you now most people on this forum are deaf!!! :d :d :d
Ah, that went well!!! :facepalm:
It should have been in all capitals and said "Why are you shouting don? Don't you know most people on this forum are deaf!!!" and then had 3 smiley faces after it.... I guess the forum software can't handle something as complex as all upper case...
svxtech, I guess you could change bellows like that, but why? Just as easy to pull the Bell housing off and just give yourself that much extra 'wriggle room'....
I find it easier, just figured I would share the trick. Especially if you're in salt water with corrosion and a used pin tool, if you round off the heads you are in for a treat, not to mention having to remove the water tube (and depending on model the reserve oil line) with the plastic fitting that breaks- as it so often does. The less you have to mess with the better. Again JMO![]()
The fitting for the remote oil line on a gen 2/bravo gimbal housing? I have a few under my beltFair cop... I've never had one of the fittings break... how difficult is it to break them?
