Saskatoon2005
Master Chief Petty Officer
- Apr 27, 2005
- 810
Hello All, and thank-you in advance for all your help. I have a 1978 Mercury Outboard. It has 7.5 H.P. and I was told it required a new stator from a 2nd rate boat motor repair guy.<br /><br /> The motor produces nice clean spark from the spark plugs but the repair guy said it was not enough to get the motor going. He said when he hooked it up to the tester that makes sure the spark jumps at leasy 1/4 of an inch that the motor would not. He says the low speed coil on the stator is cracked and probably leaking the power needed to ground before getting it to the spark plug. Is there any way I can check this? The motor was hardly used and last time used was in peak runnning condition. I really want to use it to go fishing....please help me a.s.a.p
