So I have a 1436 jon boat with a 9.9 chrysler i bought last summer that I've been (slowly) try to make a bit nicer to use. I only got it out twice last year on a small lake close to home, but I could not get it to plane out with my wife and myself and not much more weight (granted neither of us are small). I wasn't too worried on a calm, smooth glorified pond, but I'd like to and plan to hit larger, heavier traveled lakes and don't want to get run over/take all day to get to a spot.
1. I found that someone had put in, and written under the cowl, b7hs plugs in place of the b6hs i now know are recommended. Should this make much of a difference? (Planning to go out tomorrow and find out).
2. As it sits my anti cav plate sits roughly 2" below the bottom of the hull. I've read that even or slightly above is ideal, but I've also read that Jon's like the cav plate a little low. Should I raise it? I'm planning on reinforcing the hull anyway so I could easily build 2" of lift into my reinforcement (aluminum plate sandwich in the og transom).
3. What trim angle should be ideal for getting on plane and being stable? I believe I had the pin in the 2nd lowest hole last summer (could have been the third). Or does it just vary too much for there to be a "normal" setting?
4. Should I even bother with the chrysler, or ditch it and find a 15hp 2 stoke?
I appreciate any help and apologize for the novel.
