I've been reading the thread where several of you are helping the poster figure out how to wire in an isolator and it made me realize that I don't have one.
I have the Perko battery selector switch for bat 1, bat 2, and both. I have two starting batteries for the boat and typically have used the both setting until I read a thread suggesting to use bat 1 for the trip out and then bat 2 for the return trip, so now I'm confused (not hard to do for me).
I have a three bank on board charger and keep the 2 starting batteries and my 1 deep cycle plugged in whenever I'm not using the boat, so all three batteries are always kept charged and maintained. The deep cycle is hooked up to my trolling motor and nothing else, so I know that doesn't need anything else.
So question 1 is do I need an isolator and why? I have picked up from the other threads that an isolator will protect your charging system in the event the battery selector switch gets switched to off when the motor is running. I don't plan to do this and do not switch the selector when the motor is running.
Question 2 is can I continue to keep the switch in the both setting or should I go to the bat 1, bat 2 scenario?
Lastly, if I need an isolator, how do I figure out what I need. The boat in my signature is the craft I have the questions about.
Thanks for the help!
