pecheux
- Jun 9, 2006
- 1,200
Good day.
This 1997 Force by Merc (I know it's Chrysler) has been running like a charm for many years until now. Runs great at WOT but after trolling for a few minutes it will just stop. At faster idle I can tell it's missing after a shorter while. Varies between 15 seconds to one minute then I turn the handle to WOT and it will just get there and stay there without any misfiring. This OB normaly starts on first pull but when it stops when trolling (idling) it need several more agressive pulls.
I took the plugs out and the center parts are nice light brown and electrode shows no sign of wear. but the outter part shows a bit of carbon. I dont remember if I changed then last year but it has not been used much.
Also I have switched to an OMC self venting metal tank that I owned since new and showned no sign or rust. (but who knows ..) the tube inside the tank has a mesh filter.
Any suggestions on what the source of the problem may be ? I will be replacing the plugs anyway. I am confused with the fact that is runs great at WOT.
Thank you.
Thank you.
