do i need this rubber seal?
jeff in beckley
when i put my lower unit back on the seal popped off but i did not see it until the thig was back to gether. do i need it on there. 89 40 horse rude.
ob
Re: do i need this rubber seal?
Jeff if you are speaking of the rubber grommet that can be seen externally that the shift rod runs through,it is primarily there to prevent debris intrusion into the cavity area.If it were mine ,I would drop lower unit and reinstall it.You could possibly cut a clean split in it and install from the outside with shift rod in place.Good luck.
