Re: Do they make a small 110v water cooled marine generator?
They make marine generators as small as 3.0kW, BUT.....
I installed a Kohler generator 2 seasons ago in my Silverton.
There is no way you're going to buy and install a proper marine generator for anywhere near 700 bucks. I spent more than that just on hoses, wire and fittings!
Installation is way more involved than most people think- AC transfer switch, properly sized tinned wire, thru-hulls and hose for intake and exhaust, water lift muffler, sea strainer, fuel valve and tee, fuel/water seperator, etc, etc, etc.... I could go on and on.
After shopping around, the best price I could find for a new 5kW Low-CO model was $7600, with the optional sound shield adding another $200. Add taxes and it cost $8K not including all the "little" stuff.
When it was all said and done I spend $9100 total. And remember- I did ALL the work myself. It AINT cheap!
As far as running A/C with only batteries, it's been tried before and just doesn't work for more than a few minutes. The battery bank you'd need would be enormous.
Maybe you could get by with a swamp cooler:
http://www.consumerenergycenter.org/home/heating_cooling/evaporative.html
Whatever you try, good luck.
There's absolutely nothing better than ice cold A/C when on the water!
