On the trim tabs thing, yes it usually will help to get up on plane from my experience... if your boat is underpowered and/or loaded right up. My old 81 chris craft 253 absolutely needed full trim tab to put her up. With full tank of fuel and 4 or 5 people/gear on board. (tired 350 v8, omc stringer drive, not a great hull) even that took a while, sometimes people had to go to the front of the v birth for 'help' get her up on plane...
But my current boat (25ft crownline, 454 v8/merc bravo 2) will get up and go all on its own, only needs trim tabs to keep her level while on plane. Using the drive trim will get it going even better, once shes up. Enough power and you can get anything out of the water though :lol: Adjusting for a level ride is really the only reason they put them on a boat in the first place, as far as I am aware, and I try to run as little as possible at that, as it is just extra drag, ie more fuel being burnt.
