Frank Acampora
- Jan 19, 2007
- 12,004
Posted for your enjoyment. Do you have the guts to run this ?
I now have power tilt/trim and an engine with some grunt to it. And a beautiful Johnson Oakland bronze 15 pitch prop.
If the weather holds, I may be able to test this combo. I really don't know what to expect as the Chrysler 60 is significantly heavier than the 50 I removed. Significantly more power too!
Turned out that I actually needed to lower the 60 on the transom because the midleg/lower unit is 2 inches shorter than the 50. But, the water pick-up is lower so I should have more positive water flow.
There may be no increase in performance but then again----she may go like a scalded cat. No pun intended. The hull is a tunnel, not a catamaran.
Stay tuned for further developments.
