Do you have to winterize a 4 stroke Mercury O/B?
SeaingDouble
I was looking into buying a small aluminum boat with a 2005 Mercury 8.0 4 stroke on the back. It was used a few times before winter. I asked the seller if he winterized the motor and he said no because you don't have to.<br />Is this true? I did some research and it seems these outboards are water cooled which leads me to believe they should in fact be winterized.<br /><br />Thanks
Laddies
Banned
Re: Do you have to winterize a 4 stroke Mercury O/B?
All engines should be winterized before storage
SeaingDouble
I understand that winterizing is always better than not, but does water stay inside an outboard where freeze damage could occur? I'm just trying to figure why this guy would say it doesn't "need" it. I have never owned an outboard so I have no idea.
WillyBWright
Water in the gearcase would be a BIG worry if that was in there. It's been the demise of many a motor. There's a few threads right now dealing with cracked gearcases and ice is still on a whole lotta lakes. Also a HUGE reason to winteize a 4-stroke is to get the contaminated motor oil out of there before it settles to the bottom and forms a permanant sludge layer. A lot of people wait until spring, put in fresh oil just to have it turn dirty in very short order. Then they wonder "What's wrong with my motor?" DUH! :rolleyes: <br /><br />2-stroke pistons and cylinder walls are constantly bathed with oil. There's usually residual to protect them for awhile. Not true with a 4-stroke. Rusted cylinders are about certain if you don't fog the motor. Imagine the rust being scraped off the cylinder walls the first time it starts up again this spring. :eek: <br /><br />Finally, the passages in a 4-stroke carb are very small. It doesn't take much at all to varnish them to a problematic level. Print this out and bargain with him. It is extrememly unwise to neglect winterizing ANY motor! ESPECIALLY a 4-stroke outboard! It leads to problems which may very well already exist, leaving them for YOU to deal with. :mad: <br /><br />As far as the water in the motor part, no problem if the motor was stored in the running position or anywhere close. They're self-draining. So at least that shouldn't be a worry. :)
SeaingDouble
o.k., so they are self draining which is good. Well the motor in question is a 2005 8.0 that was supposedly only used a few times so I doubt there is any sludge in there yet. But then there is the rusty cylinder walls...I may have to think about this one.<br /><br />Thanks Willy
