Do you know what this is?
Grub54891
Re: Do you know what this is?
That looks like tge speedometer tube,does it have a speedo,and does it work?
Frank Acampora
Grub was correct: That is the speedometer tube and coupler. There is an impact hole in the front of the lower unit, below the water line, that connects to a cavity inside. The top of the cavity has a rubber plug and the tube comes from the plug up and out the midleg. Then, the flattened and no longer useful coupler connects to the black plastic tube running to the speedometer.
