Do you think I have damaged my motor?
Grant123
I have a 1982 60HP Mariner 2cyl 2 stroke. My impeller shreaded and my motor cut out from over heating. Smoke was coming form under the cover. The motor did not seized and it did restart immediately but I did not run it. Since the motor has not seized do you think I have escaped major damage? Should some sort of alarm have gone off?
Chris1956
Re: Do you think I have damaged my motor?
Grant, Now that the motor has cooled off, perform a compression test. if the cylinders are even and 100+PSI, you should be OK, after you install the necessary new waterpump parts.
Grant123
Thanks Chris, hope so. Should there be some type of high temp warning on my motor?
tashasdaddy
should be a warning horn. may be sender or horn is bad.
