Half feels better in my hand but I have trouble getting a double wrap on my cleats so I don't like it.
hi everyone , my boat needs new dock lines , what diameter should i get ? the boat is a 1989 thundercraft 220 magnum , i think it weighs around 3500 pounds .. thanks .
?? if you tie the right way 5/8 will fit cleats, tieing a boat is very easy and simple if you just remember a few knots
http://www.animatedknots.com/cleat/...ge=LogoGrog.jpg&Website=www.animatedknots.com
GL Ron
I use lines with a spliced loop. I like to use the spliced loop one the cleat and the non-spliced loop is tied to the piling on the dock using a clove hitch with 2-half hitches, or at least two-turns and a half hitch. This typically negates the need to double-wrap a cleat hitch on the cleat. This also allows a smaller cleat to take a slightly larger line, or a single cleat to allow several lines (2 works fine, 3 gets crowded. Once the dock lines are tied to the dock they stay there all season so when I get back to the dock the lines are already all the correct length and I only need to go around and attach the sliced loop to the apropriate cleat. (I use color coded line to differentiate bow and strn lines from spring lines). I keep a spereate set of lines on the boat for typing up to other boats and transient docks.
