Dodge CTD Trans O/D.
MRS
Can just the O/D unit on the trans go out only or is it the whole trans that needs to be changed? I was about ready to take in for yearly service and it started to shift back and fourth why to manys times at 45 to 55 mph. once above 60 mph seems to run alright that is running with out any load on truck.
jimr
Re: Dodge CTD Trans O/D.
it may be as simple as a bad Throttle position sensor.
MRS
jimr, Thanks for reply I have been on a few forum sites did not get any replys but yours so I did drop off at dealers today. I need my truck or I can not take my boat anywhere!!!! Thanks for the reply I will post what dealer said just to let you know what was wrong. Thanks again......
MRS
jimr, it was the batteries they had corrostion on them and were not sending enough volts to the sensors for the trans. Weird but they said on 2000 thru 2002 it is real sensitive about enough volts getting to the sensors seems to be working ok now just letting you know Thanks.
