On of my friends inherrited an old outboard, a 18 HP 2 cyl 2stroke Perkins Outboard. From the design it looks to be somewhere in sixties. Front of cowling looks like a Homelite. This motor has VERY low hours. The paint on tiller trottle gears are barely worn off in small scratches !!!. However someone without knowledge has messed with it. The lower spark plug has been overturqued and it needs a helicoil. There has been water in lower unit, as someone probably changed the impeller and not replaced the shift rod gasket !! A 3/4" retainernut and gasket around the shiftrod misses. A ball bearing in lower unit is done, gears and rest of bearings look spotless. Water pump looks brand new, as rest of motor. Will it be possible to get the seal and hardward for the shift rod ?? Does anyone know it ??
