pureroundcircle
- Sep 12, 2007
- 5
Before I get the expected responses that yamaha oil injection is great here is my situation: my oil pump housing is cracked, it is leaking oil out the adjustment shaft area, and is completly missing the throttle linkage, also the oil tank has JB weld on it and the cap is cracked. The boat and motor were dirt cheap, but in need of some help. I'm not really interested in investing much money in keeping the oil injection, I'd prefer just save the extra cash and go to premix.
I have read that you can remove the pump and pull the driveshaft and then re-assemble and plug the oil line and disconnect sensors, or short them to ground. I pulled the driveshaft and re-attached the oil pump to the block, but I just wanted to make sure i've done all that is needed before starting her up. MY question is is that ALL i need to do?
Thanks,
Paul
Thanks,
Paul
