Does anyone with a similar boat as mine have a preference on a prop that like?
alamantia
1) Performance issue you are trying to correct.
Greater top speed
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Aluminum 3 blade
3) Current prop diameter and pitch (required).
13" diameter with a 19" pitch
4) Wide open throttle RPM and speed with an average load (very helpful)
I never made it up to WOT, the boat planes off around 4000 and I cab back it down to 3200 while still maintaining plane. At 5000 RPM the boat went 39 on the GPS
5) Engine/drive make, model, year, and HP
260/350 mercruiser I/O with a 1.47 (i think) alpha 1
6) Boat make model, year, length and weight
1987 Wellcraft Elite 222 @ 4000 lbs dry, with gas and 2 people in it I suspect around 5000lbs
My first weekend ever driving a boat since I was 10 years old was unbelievable. My 25 year old wellcraft purred like a kitten. She got op on plane and and ran strong and smooth on my maiden voyage. I never placed the throttle in the wide open position because at about 3/4 throttle it would run at about 5000RPM, I did not want to exceed 5000RPM. When I bought the boat from the previous owner I took notice to the fact that he had little kids and water skis and tubes in his garage, he also lived on a small lake. I never did inquire as to what prop he had on the boat and why. I deduced that it was 13" by measuring it, and the number on the side of the prop said 19 so I think the pitch is 19" I am guessing that due to the size of his lake and the fact he towed skiers and I think the prop is a 19" pitch that I could go up to a 14" diameter 21" prop. But since I am new to this I decided to look thru the forum only to find out that propl selection looks to be a heck of an ordeal. I figure I see a lot of 21-24' single engine boats when I am out, perhaps there are people on this forum who can give me their personal experiances and point me in the right direction.
Thanks
Maclin
Re: Does anyone with a similar boat as mine have a preference on a prop that like?
When I plug in the ratio, speed, rpm and pitch I show slippage of 36% which is way high. When I put in 15% slip that calcs to 50mph+ at 5000 rpm. I think the prop is a problem, perhaps it is the diameter. A 19 pitch should net you 49 or so at 4800 with 15% slip, so the pitch is not really the issue. All of this assumes the 1.47 drive ratio is correct.
http://www.marksmarineinc.com/prop_calc.aspx
steelespike
The diameter seems really small. Props listed here are all 14" or more some over 15.
May have been selected specifically for water sports.
alamantia
I removed the 13" diameter 19" pitch prop and replaced it with a quicksilver 14.25" diameter 21" pitch prop. I hope to try it this weekend, I hope I notice a difference.
Maclin
It should behave differently in a positive way I'm sure. Great looking boat by the way :)
Robbabob
My $.02
Probably a good change and hope it keeps you from the over rpm. A little slower out of the hole, of course, but it may not be too bad.
Happy boating, again!
