Re: does it damage vro if plugged to premix
I disagree- it can damage the VRO if there is no oil going to the pump. The piston that pumps the oil gets lubricated by the oil. If you cut off the oil supply to the VRO, the piston can seize in the bore. I know- it happened to me. The oil piston seized and that seized the fuel pump diaphragm- guess what? No fuel, no run. When pricing the pumps, a VRO assembly was $300. I opted to replace the entire pump with a straight fuel pump and pre-mix like I had been doing. Cost? $48.00. <br /><br /> So, yes, it can cause damage. <br /><br />UFM82
