scottcooper
- Jun 18, 2009
- 6
I have a 1983 85 hp Force and was troubleshooting a no fire issue on #1 cylinder and found it was simply a loose connector from module to coil
However, I noticed the wiring wasn't correct in that the #2 module's orange wire is supposed to be connected to #3 cylinder coil but instead it's connected to Red. I'm sure you know this but, 1 module fires cylinders 1 and 2; 2nd module fires #3 cylinder with red wire supposed to be unplugged/taped off. I connected the #3 coil to the orange wire and get no spark. My question is, is it ok that the #3 coil is connected to the red wire instead of the orange on the module or is that causing the plug to fire at the wrong time? It seems logical to me when I think of a car that it's affecting the firing order but I'm no all that understanding of how this ignition system works exactly. Any insight is appreciated. Thanks
